15 years agorunning program in SRAM doesn't work
Hi all, I am running my C program in NiosII and I need to print out the result on the console. There are a 512KB SRAM and an 8MB SDRAM on the board. The program works fine with the SDRAM. ...
14 years agoIf you use Qsys it should be possible to parametize the generic tristate controller with the SRAM timing values to create your own controller for that memory.
