15 years agorunning program in SRAM doesn't work
Hi all, I am running my C program in NiosII and I need to print out the result on the console. There are a 512KB SRAM and an 8MB SDRAM on the board. The program works fine with the SDRAM. ...
14 years agothanks again,
i found a weird behavior, when i test the sram it happens(attached screem shot:memory), some positions are wrong. why? isnt the physical device working? or isnt the sram component(TERRASIC_SRAM) working? other thing is that i change the reset and exception vector in my SOPC design but when i open the BSP editor and i open the linker script just the reset and exception vector are in the sram(linker_script) so i have change manually it
