15 years agorunning program in SRAM doesn't work
Hi all, I am running my C program in NiosII and I need to print out the result on the console. There are a 512KB SRAM and an 8MB SDRAM on the board. The program works fine with the SDRAM. ...
14 years agothank fheineman and caridee,
here you have a screem shot but i m using SOPC builder instead of Qsys (and Quartus II 11.0sp1 Web Edition (32-Bit)).can thAT generate any problem? My board is cyclone iv DE2-115. my project run from sdram but when i change linker region(BSP editor), reset vector and exception vector(SOPC) from sdram to sram, the file .elf cant be downloaded: "Hardware configuration' has encountered a problem. Downloading ELF Process failed"
