15 years agorunning program in SRAM doesn't work
Hi all, I am running my C program in NiosII and I need to print out the result on the console. There are a 512KB SRAM and an 8MB SDRAM on the board. The program works fine with the SDRAM. ...
14 years agoHi, do you have flash in ur qsys system? If yes, I suppose you are gonna have 2 generic tristate controllers, tristate bridge and a tristate pin sharer connecting together. In your top level design, pls check its connection. For 16 bit sram, u should ignore the first bit and so on. I encourage you to have a look on qsys handbook, Tristate chapter. Hope it helps.
