15 years agorunning program in SRAM doesn't work
Hi all, I am running my C program in NiosII and I need to print out the result on the console. There are a 512KB SRAM and an 8MB SDRAM on the board. The program works fine with the SDRAM. ...
15 years agoHi srhikari,
Did you get this working? I have exactly the same problem trying to run the software on SRAM. I even tried running it on the Cyclone III NEEK dev kit with the same results. It runs fine with SW running in SDRAM, but no Nios II Console output when using SSRAM. Yet another glitch in Qsys/Nios II. Please let us know if you find a solution, I will do the same.
