12 years agoRunning NIOS program from external SDRAM
Hi, How would one create or modify a linker script to get a Nios program to run from external SDRAM rather on on-chip RAM? I have created a Qsys system with a NIOS and SDRAM controller. The...
12 years agoThanks for the reply Slacker.
My next question is how would I implement this? I am using a DE0-nano board which has EEPROM and an EPCS64 serial configuration device which I could use to store the code at first . I can load the NIOS II program there but how do I then point the reset address to it? How would I create this boot copier/loader and get it to start copying the code to the SDRAM when the NIOS starts? . Would I need to write start up code? I have wrote code for physical MCUs before and I know that a linker script is required to memory map the sections for the MCU and then some start-up assembler code which runs from the reset address which then jumps to main(). Are these created automatically by the Nios IDE or how does it work? Thanks, Paul
