21 years agorunning Linux without flash
Hello, I have a custom board without flash memory. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif So I wonder, if it's possible to load the Kernel and rootfs ramdisk ...
21 years agoNow I've come so far: I've compiled the u-boot for Nios II and I can upload to the board with nios2-download. I get some status messages but no prompt. I'm using the PK1C20 design.
U-Boot 1.1.2 (Jul 5 2005 - 16:30:56)
CPU : Nios-II
SYSID : 505a763f, Wed Dec 13 04:10:46 1995
BOARD : Psyent PK-1C20
Using default environment
In: serial
Out: serial
Err: serial Here is my configuration file: /*
* (C) Copyright 2004, Psyent Corporation <www.psyent.com>
* Scott McNutt <[email protected]>
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
# ifndef __CONFIG_H# define __CONFIG_H
* BOARD/CPU
*----------------------------------------------------------------------*/# define CONFIG_PK1C20 1 /* PK1C20 board */# define CONFIG_SYS_CLK_FREQ 50000000 /* 50 MHz core clk */
# define CFG_RESET_ADDR 0x01820800 /* Hard-reset address */# define CFG_EXCEPTION_ADDR 0x01820820 /* Exception entry point*/# define CFG_NIOS_SYSID_BASE 0x01820c90 /* System id address */# define CONFIG_BOARD_EARLY_INIT_F 1 /* enable early board-spec. init*/
* CACHE -- the following will support II/s and II/f. The II/s does not
* have dcache, so the cache instructions will behave as NOPs.
*----------------------------------------------------------------------*/# define CFG_ICACHE_SIZE 2048 /* 4 KByte total */# define CFG_ICACHELINE_SIZE 32 /* 32 bytes/line */# define CFG_DCACHE_SIZE 2048 /* 2 KByte (II/f) */# define CFG_DCACHELINE_SIZE 4 /* 4 bytes/line (II/f) */
* MEMORY BASE ADDRESSES
*----------------------------------------------------------------------*/# define CFG_FLASH_BASE 0x01000000 /* FLASH base addr */# define CFG_FLASH_SIZE 0x00800000 /* 8 MByte */# define CFG_SDRAM_BASE 0x00000000 /* SDRAM base addr */# define CFG_SDRAM_SIZE 0x01000000 /* 16 MByte */
//#define CFG_SRAM_BASE 0x00800000 /* SRAM base addr */
//#define CFG_SRAM_SIZE 0x00200000 /* 2 MByte */# undef CFG_SRAM_BASE# undef CFG_SRAM_SIZE
* MEMORY ORGANIZATION
* -Monitor at top.
* -The heap is placed below the monitor.
* -Global data is placed below the heap.
* -The stack is placed below global data (&grows down).
*----------------------------------------------------------------------*/# define CFG_MONITOR_LEN (128 * 1024) /* Reserve 128k */# define CFG_GBL_DATA_SIZE 128 /* Global data size rsvd*/# define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024)
# define CFG_MONITOR_BASE TEXT_BASE# define CFG_MALLOC_BASE (CFG_MONITOR_BASE - CFG_MALLOC_LEN)# define CFG_GBL_DATA_OFFSET (CFG_MALLOC_BASE - CFG_GBL_DATA_SIZE)# define CFG_INIT_SP CFG_GBL_DATA_OFFSET
* FLASH (AM29LV065D)
*----------------------------------------------------------------------*/# define CFG_MAX_FLASH_SECT 128 /* Max# sects per bank */# define CFG_MAX_FLASH_BANKS 1 /* Max# of flash banks */# define CFG_FLASH_ERASE_TOUT 8000 /* Erase timeout (msec) */# define CFG_FLASH_WRITE_TOUT 100 /* Write timeout (msec) */# define CFG_FLASH_WORD_SIZE unsigned char /* flash word size */
* ENVIRONMENT -- Put environment in sector CFG_MONITOR_LEN above
* CFG_RESET_ADDR, since we assume the monitor is stored at the
* reset address, no? This will keep the environment in user region
* of flash. NOTE: the monitor length must be multiple of sector size
* (which is common practice).
*----------------------------------------------------------------------*/# undef CFG_CMD_ENV# undef CFG_CMD_FLASH# define CFG_ENV_IS_NOWHERE /* Environment in flash */# define CFG_ENV_SIZE (64 * 1024) /* 64 KByte (1 sector) */
//#define CONFIG_ENV_OVERWRITE /* Serial change Ok */
//#define CFG_ENV_ADDR (CFG_RESET_ADDR + CFG_MONITOR_LEN)
//#undef CFG_ENV_SIZE# undef CONFIG_ENV_OVERWRITE# undef CFG_ENV_ADDR
* CONSOLE
*----------------------------------------------------------------------*/# define CFG_NIOS_CONSOLE 0x00020c00 /* UART base addr */
# define CFG_NIOS_FIXEDBAUD 1 /* Baudrate is fixed */# define CONFIG_BAUDRATE 9600 /* Initial baudrate */# define CFG_BAUDRATE_TABLE {9600} /* It's fixed;-) */
# undef CFG_CONSOLE_INFO_QUIET
//#define CFG_CONSOLE_INFO_QUIET 1 /* Suppress console info*/
* DEBUG
*----------------------------------------------------------------------*/# undef CONFIG_ROM_STUBS /* Stubs not in ROM */
* TIMEBASE --
* The high res timer defaults to 1 msec. Since it includes the period
* registers, we can slow it down to 10 msec using TMRCNT. If the default
* period is acceptable, TMRCNT can be left undefined.
*----------------------------------------------------------------------*/# define CFG_NIOS_TMRBASE 0x01820c40 /* Tick timer base addr */# define CFG_NIOS_TMRIRQ 3 /* Timer IRQ num */# define CFG_NIOS_TMRMS 1 /* 10 msec per tick */# define CFG_NIOS_TMRCNT (CFG_NIOS_TMRMS * (CONFIG_SYS_CLK_FREQ/1000))# define CFG_HZ (CONFIG_SYS_CLK_FREQ/(CFG_NIOS_TMRCNT + 1))
* STATUS LED -- Provides a simple blinking led. For Nios2 each board
* must implement its own led routines -- leds are, after all,
* board-specific, no?
*----------------------------------------------------------------------*/# define CFG_LEDPIO_ADDR 0x01820c80 /* LED PIO base addr */# define CONFIG_STATUS_LED /* Enable status driver */
# define STATUS_LED_BIT 1 /* Bit-0 on PIO */# define STATUS_LED_STATE 1 /* Blinking */# define STATUS_LED_PERIOD (500/CFG_NIOS_TMRMS) /* Every 500 msec */
* ETHERNET -- The header file for the SMC91111 driver hurts my eyes ...
* and really doesn't need any additional clutter. So I choose the lazy
* way out to avoid changes there -- define the base address to ensure
* cache bypass so there's no need to monkey with inx/outx macros.
*----------------------------------------------------------------------*/# define CONFIG_SMC91111_BASE 0x81830000 /* Base addr (bypass) */# define CONFIG_DRIVER_SMC91111 /* Using SMC91c111 */# undef CONFIG_SMC91111_EXT_PHY /* Internal PHY */# define CONFIG_SMC_USE_32_BIT /* 32-bit interface */
# define CONFIG_ETHADDR 08:00:3e:26:0a:5b# define CONFIG_NETMASK 255.255.255.0# define CONFIG_IPADDR 192.168.2.21# define CONFIG_SERVERIP 192.168.2.16
* COMMANDS
*----------------------------------------------------------------------*/# define CONFIG_COMMANDS (CFG_CMD_BDI |
CFG_CMD_DHCP |
CFG_CMD_ECHO |
/*CFG_CMD_ENV |
CFG_CMD_FLASH |
*/ CFG_CMD_IMI |
CFG_CMD_IRQ |
CFG_CMD_LOADS |
CFG_CMD_LOADB |
CFG_CMD_MEMORY |
CFG_CMD_MISC |
CFG_CMD_NET |
CFG_CMD_PING |
CFG_CMD_RUN |
CFG_CMD_SAVES )# include <cmd_confdefs.h>
* MISC
*----------------------------------------------------------------------*/# define CFG_LONGHELP /* Provide extended help*/# define CFG_PROMPT "==> " /* Command prompt */# define CFG_CBSIZE 256 /* Console I/O buf size */# define CFG_MAXARGS 16 /* Max command args */# define CFG_BARGSIZE CFG_CBSIZE /* Boot arg buf size */# define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print buf size */# define CFG_LOAD_ADDR CFG_SDRAM_BASE /* Default load address */# define CFG_MEMTEST_START CFG_SDRAM_BASE /* Start addr for test */# define CFG_MEMTEST_END CFG_INIT_SP - 0x00020000
# endif /* __CONFIG_H */
