20 years agoRunning Linux inplace, from EPCS or CFI
I have run into some problems continuing on in my development with the Altera Cyclone II DSP dev board and uCLinux, related to memory interfacing. (At this stage I have uCLinux running on this b...
20 years agothe 256M limitation is on inst master.
the data master shouldn't have such issue. so you can run uclinux on 128M, and use 1G-128M for data logging, which will be accessed by data master only. the sopc window will refuse to generate. but you may try to run generate script manually.
