20 years agoRunning Linux inplace, from EPCS or CFI
I have run into some problems continuing on in my development with the Altera Cyclone II DSP dev board and uCLinux, related to memory interfacing. (At this stage I have uCLinux running on this b...
20 years agoI did hack the scripts.
In uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/PTF/SystemPTF/Module.pm, after line 176, in function getSize{}, I added: } elsif ($data_width == 64) { $size = 1 << ($addr_width + 3) } elsif ($data_width == 128) { $size = 1 << ($addr_width + 4) } This is required to use more than 64 MB of RAM, so I did this to use 128 MB. I can't use the full 256MB that is on the DIMM, since the other peripherals still need to be mapped into memory. I did think about trying to hack the SOPC build scripts. However, if there is a genuine restriction to 256MB in the instruction master of the Nios, then hacking the scripts will just break the CPU logic. I had a look at the generated VHDL, but there is just too much of it to manually edit it.
