20 years agoRunning Linux inplace, from EPCS or CFI
I have run into some problems continuing on in my development with the Altera Cyclone II DSP dev board and uCLinux, related to memory interfacing. (At this stage I have uCLinux running on this b...
20 years agoI understand your problem.
You may start working with 128MB sdram. It is still possible to hack the nios2/sopc build scripts, those are perl and java. You may try it at a later time.
