20 years agoRunning Hello Word example from Nios II SDK Shell
Hi all...
How can I run the "Hello Nios II" example from Nios II SDK Shell ? I tried to use these comands:$ nios2-elf-gcc -o hello.o hello.c
$ nios2-elf-gcc -nostartfiles -g -nostdlib -Wl,--gc-sections -Wl,-static -mhw-mul -mhw-mulx -mno-hw-div -o hello hello.o
$ elf2flash --silent --input=hello --flash=U5 --boot=`$QUARTUS_ROOTDIR/sopc_builder/bin/find_sopc_component_dir altera_nios2`/boot_loader_cfi.srec --outfile=./hello.flash --sim_optimize=0 --base=0x00000000 --end=0x007fffff --reset=0x00000000
$ nios2-flash-programmer --input=./hello.flash --sof=`$QUARTUS_ROOTDIR/sopc_builder/bin/find_sopc_component_dir altera_nios_dev_board_stratix_1s10_es`/system/altera_nios_dev_board_stratix_1s10_es.sof --device=1 --base=0x00800000
20/10/2005 11:47:26 - (INFO) nios2-flash-programmer: Launching Quartus Programme
r to download:
c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es/syste
Pre-Reading 35KBytes of data from U5:
********************* (2.641 sec).
20/10/2005 11:47:47 - (INFO) nios2-flash-programmer: Success. Zero bytes writte
n to U5-
(because device matched contents of ./hello.flash)
20/10/2005 11:47:47 - (INFO) nios2-flash-programmer: Flash programming complete There are no errors from these commands... But I couldn't get the "Hello from Nios II!" message in nios2-terminal. What is wrong? Thanks, Maikon.1 Reply
--- Quote Start --- originally posted by maikon@Oct 20 2005, 09:10 AM hi all...how can i run the "hello nios ii" example from nios ii sdk shell ?
i tried to use these comands:
$ nios2-elf-gcc -o hello.o hello.c $ nios2-elf-gcc -nostartfiles -g -nostdlib -wl,--gc-sections -wl,-static -mhw-mul -mhw-mulx -mno-hw-div -o hello hello.o $ elf2flash --silent --input=hello --flash=u5 --boot=`$quartus_rootdir/sopc_builder/bin/find_sopc_component_dir altera_nios2`/boot_loader_cfi.srec --outfile=./hello.flash --sim_optimize=0 --base=0x00000000 --end=0x007fffff --reset=0x00000000 $ nios2-flash-programmer --input=./hello.flash --sof=`$quartus_rootdir/sopc_builder/bin/find_sopc_component_dir altera_nios_dev_board_stratix_1s10_es`/system/altera_nios_dev_board_stratix_1s10_es.sof --device=1 --base=0x00800000 20/10/2005 11:47:26 - (info) nios2-flash-programmer: launching quartus programme r to download: c:/altera/kits/nios2/components/altera_nios_dev_board_stratix_1s10_es/syste m/altera_nios_dev_board_stratix_1s10_es.sof pre-reading 35kbytes of data from u5: |----.----+----.----| ********************* (2.641 sec). 20/10/2005 11:47:47 - (info) nios2-flash-programmer: success. zero bytes writte n to u5- (because device matched contents of ./hello.flash) 20/10/2005 11:47:47 - (info) nios2-flash-programmer: flash programming completethere are no errors from these commands... but i couldn't get the "hello from nios ii!" message in nios2-terminal.
what is wrong?
thanks,
maikon.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10480)</div> --- Quote End --- I think your uart has some problem,i am sorry i can not write in english very well.
