21 years agoRunning from internal ROM
Hello all, Can I ask if it is supposed to be possible to run from an internal ROM? This means not using a bootloader at all. setting reset to an internal on chip ROM. In this case, do...
21 years agoAre there some linker switches to reduce the ROM size? I don't see how code+initialised data comes to 8694, certainly not from the map file? Are those other sections being lumped into the ROM in error?
Compiling alt_main.c... Linking ems_boot.elf... Info: (ems_boot.elf) 8694 Bytes program size (code + initialized data). Info: 16382 KBytes free for stack + heap. Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) Post-processing to create ems_boot_rom.hex Build completed [SOPC Builder]$ nios2-elf-objdump -h ems_boot.elf ems_boot.elf: file format elf32-littlenios2 Sections: Idx Name Size VMA LMA File off Algn 0 .entry 00000020 01000000 01000000 00000094 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .exceptions 000000d8 01000020 01000020 000000b4 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .text 000018c8 010000f8 010000f8 0000018c 2**3 CONTENTS, ALLOC, LOAD, READONLY, CODE 3 .rodata 000001d2 010019c0 010019c0 00001a54 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .rwdata 00000020 00000000 00000000 00000074 2**2 CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA 5 .bss 00000644 00000020 00000020 00000094 2**2 ALLOC, SMALL_DATA 6 .sdram 00000000 00000664 00000664 00001c26 2**0 CONTENTS 7 .epcs_controller 00000000 01004800 01004800 00001c26 2**0 CONTENTS 8 .ems_boot_rom 00000002 01001b92 01001b92 00001c26 2**0 CONTENTS 9 .comment 000002ec 00000000 00000000 00001c28 2**0 CONTENTS, READONLY 10 .debug_aranges 00000108 00000000 00000000 00001f18 2**3 CONTENTS, READONLY, DEBUGGING 11 .debug_pubnames 0000010b 00000000 00000000 00002020 2**0 CONTENTS, READONLY, DEBUGGING 12 .debug_info 00003266 00000000 00000000 0000212b 2**0 CONTENTS, READONLY, DEBUGGING 13 .debug_abbrev 00000821 00000000 00000000 00005391 2**0 CONTENTS, READONLY, DEBUGGING 14 .debug_line 00000b84 00000000 00000000 00005bb2 2**0 CONTENTS, READONLY, DEBUGGING 15 .debug_frame 00000198 00000000 00000000 00006738 2**2 CONTENTS, READONLY, DEBUGGING 16 .debug_str 00000977 00000000 00000000 000068d0 2**0 CONTENTS, READONLY, DEBUGGING /cygdrive/f/projects/emshw/full_featured/software/ems_boot/release [SOPC Builder]$
