21 years agoRunning from Flash
Hello I have a basic question: can I run sofftware from Flash memory (i.e. define the program memory and the ROM memory in Flash while leaving the read-write memory in sram for example)? I know...
21 years agoThanks monkeyboy
It looks like quite a lengthly procedure. I will try it anyway. However, I have two other questions: 1. Is it possible to run the program from flash without running the Flash Programmer ? i.e I want to just run it from the IDE, have the IDE download it to the flash and run, the same way it runs from RAM. 2. Will software breakpoints be supported in the future ? Isn't it possible to use software breakpoints that are determined before the compilation and download ?
