20 years agorunning from flash
Hi brothers!!!
I would like to test if my program/applicattion is available to run from flash directly, it is, don't pass the program to some sram before execute as usually works the system. - In SOPC builder I have configured that program memory be at flash region. - I configure in NIOS IDE project that program memory be in flash again. - I program with flash programer from NIOS IDE the flash while my nios is load on the FPGA. But nothing happens.... I think that something is wrong.... Somebody have use this tipology sometimes???? How you specify to the system that the program must run from flash and not dowload to ram?? Thank you!!!!! Pixel1 Reply
Working now with no problem!!!!
THANK YOU!!!!! Pixel
