19 years agoRunning from ex sram
Hi, my custom board is now working with the exception of the NIOS. I can run the prog from external 16bit sram via JTAG, no problem. But when I use the flash programmer the nios will not bo...
19 years agoYou should use less tla (http://en.wikipedia.org/wiki/tla), I do not understand most of them. It seemed to me that booting from flash was pretty straight forward. If you find time to explain what your problem was and how you solved it, it will be appreciated.
IzI
