19 years agoRunning from ex sram
Hi, my custom board is now working with the exception of the NIOS. I can run the prog from external 16bit sram via JTAG, no problem. But when I use the flash programmer the nios will not bo...
19 years agoCheck your reset circuitry, if you have none, add a reset button with a debouncer. I have recently had reset problems (maybe a problem in the PLL stability) and I had to extend my reset delay from 2ms to 500ms. Before my software was running fine after I pushed the reset button, but the software (uCLinux) crashed after the power up.
IzI
