19 years agoRunning from ex sram
Hi, my custom board is now working with the exception of the NIOS. I can run the prog from external 16bit sram via JTAG, no problem. But when I use the flash programmer the nios will not bo...
19 years agoOooops,
just found out that the flash programmer does not work at all. I assumed it deleted the EPCS before programming it. Instead, the image programmed via quartus still sits there ....(assumed the EPCS got cleared before reprogramming it) Did a dump via command line, the HW image programmed by flash programmer is not there. despite verify ok.......... If I do a JIC programming via the SFL then i can dump the config data..... suggestions?
