19 years agoRunning from ex sram
Hi, my custom board is now working with the exception of the NIOS. I can run the prog from external 16bit sram via JTAG, no problem. But when I use the flash programmer the nios will not bo...
19 years agoI checked the output of the flash programmer and it seems perfectly OK (no changes to the Flash content since a previous attempt already succeeded).
Are you trying to run a hello world that uses the jtag_uart, it the board is not connected to a PC and the Jtag-uart terminal is not running, a printf to the jtag-uart will halt the execution of the software. IzI
