19 years agoRunning from ex sram
Hi, my custom board is now working with the exception of the NIOS. I can run the prog from external 16bit sram via JTAG, no problem. But when I use the flash programmer the nios will not bo...
19 years agoYou didn't mention how you're programming the flash...command line or via the IDE. Also, when booting from the EPCS you must set the reset address (in SOPC Builder) to the small onchip memory (which is part of the EPCS component).
Cheers, - slacker
