12 years agoRunning code on a specific card
Hi, here's my problem: I have a design in Quartus II integrating a Nios II cpu and everything is fine when running a simple template. Now I have another board connecting with a USB cable. When...
12 years agoIs the second board exactly the same as the working one?
If you are trying to run the same Nios design on a different hardware configuration, you need to recompile the design. Please describe better the problem: what's the error message? Do you get it when loading Nios firmware or when you configure the fpga?
