20 years agoRunning Altera Nios2 Multiprocessor Tutorial
Hello all, Has anyone had any luck running Altera's Multiproc tutorial. I have tried several times on different machines with no success. I am running the Standard project for the...
20 years ago --- Quote Start --- originally posted by hhh_gjf@Apr 3 2006, 05:11 AM thank you ,paolo.gai."no message appears", mean that in my nios ii terminal ,there is no print message as tuturial.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13976)
--- quote end ---
--- Quote End --- ...ok... so I guess the terminal started correctly. Also check that the system library for each CPU has the right jtag uart set up, and also check all the debug configuration... After that, I have no idea, because JTAG uarts have always been working for me... Paolo
