20 years agoRunning Altera Nios2 Multiprocessor Tutorial
Hello all, Has anyone had any luck running Altera's Multiproc tutorial. I have tried several times on different machines with no success. I am running the Standard project for the...
20 years agoYes... the behavior is quite strange.
- for sure I can confirm also in other demos I did that CPUID are not assigned in the order they appear in the SOPCBuilder Tab. - the behavior you are having is quite strange... The only times a CPU stopped workning when downloading the other one was when by downloading the second I was also reprogramming the FPGA... or when the 2 CPUs were sharing the data space, which is not your case... - whan you say "no message appears", what do you mean? does the Nios II terminal starts correctly? Paolo
