dim1
2 months agoRun-time errors using EMIF in Agilex 5 NIOS-V design
Hello, I am using Quartus Prime Pro 26.1.1, with the Agilex 5 development board (AXE5-Eagle). I am trying to run the NIOS-V code from the LPDDR4 memory, using JTAG to download/debug. The reset and e...
dim1
2 months agoHello Radu,
Thank you for the detailed explanation!
In the IP catalog, I see AXI Address Span Extender IP.
Is the AXI Address Span Extender IP equivalent to the Address Span Extender? Would not that be better to use, considering that the EMIF so_axi4 is an AXI4 bus?
Another question: In the EMIF IP User Guide, in Table 12 Limitations on Narrow Read Transfer, in the Non-Lockstep configuration, when only the primary controller is used, does it mean that narrow read is supported on all Agilex 5 D and E series devices, except on the two devices listed in the table?
Thank you,
D.
