21 years agoRun from flash and use flash device driver?
I'm planning to store my program in flash and also store data using the flash device driver. Individually everything works: I can run out of RAM and write data to flash. If I run from flash (e.g....
20 years agoi'm not familier with quartos ide to perform this task (of assigenning pins) but if you will open the file *.qsf you could text lines that will define the pins , look at the standart project for exampel
