wuxin
1 year agoRUN configuration about Byte stream device
hello I want run program on 2 NIOS core。one NIOS core for application, and the other one for stack。 when I open target configuration, there display two NIOS core and one byte-stream-device。 whi...
tehjingy_Altera
1 year agoHi
The view that you are getting looks ok.
You should be selecting the processor instance instead of the Byte stream device.
The byte stream device is the usb blaster that you are using.
To flash the nios you would need to select the instance you would like to flash.
In your case there are instance 0 and instance 1.
Jingyang, Teh
