21 years agoRUN AS HARDWARE error
After I install Quartus5.0 Nios5.0,I find these errors comes out frequently. Using cable "ByteBlasterII ", device 1, instance 0x00
Processor is already paused
Reading System ID at address 0x0200...
21 years agohi mountain8848,
you said " The fact : 1. Using ByteBlasterII will cause those error. 2. Using ByteBlasterMV turn out OK! I use byteblasterMV to try the run... function, but the niosII display jtag device can not surport this download cable, maybe the cyclone device only surport byteblasterII or usb blaster, how do you use byteblasterMV as a jtag cable?
