20 years agoRUN AS HARDWARE error
hello any one !! In my custom board,FPGA works well when I download *.pof by AS mode or *.sof by JTAG mode, but I get the error information as following when I "RUN AS HARDWARE" in NIOSII IDE. ...
20 years agoJesse, thanks a lot for your advices!
I am a new man for NIOSII, and how can I try it with "on_chip ram"? set it in SOPC builder? Another, Something new take place in my work today? When I "run as hardware" , sometimes I can downloading, sometimes I get the above error information and sometimes I get the errors information as following: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x02000908: verified Downloading 01000020 ( 0%) Downloading 01010000 (96%) Downloaded 67KB in 1.9s (35.2KB/s) Verifying 01000020 ( 0%) Verify failed Leaving target processor paused and the most case is the last one!! I check the PCB routing and it is ok but I can not sure if SDRAM is ok now. I had asked for the answer from other forum; some people had the same error information as I have, but I can not get the answer from them.
