15 years agoRun and debug nios project
Hello, I am running a c file on niosii to check if the LEDs are working or not using buttons. This is my C file: #include <stdio.h> // for uart# include <unist...
15 years agoYou can't use 1us period! The processor can't operate with so a high rate of interrupt. At fclk=50MHz that would mean only 50 cycles!!!
You must modify timer in sopc builder, regenerate the system and recompile the fpga design. You should use a period 100us or greater. Usually a 1ms period is pretty enough for most applications. Cris
