16 years agoRS232 with uCLinux
Hi, I am trying to set up communication between a PC and a DE2-70 board running uCLinux via the serial port. When booting uCLinux it detects the UART component alright. I naively assumed that i...
16 years ago --- Quote Start --- Am I right in thinking that if within uCLinux run "cat /dev/urandom /dev/ttyS0", I should - given I have the correct baud rate etc. is set on the host (equal to what I set in SOPC builder) - receive a stream of random data? --- Quote End --- Yep. (if urandom is not configured not to be provided) -Michael
