16 years agoRS232 with uCLinux
Hi, I am trying to set up communication between a PC and a DE2-70 board running uCLinux via the serial port. When booting uCLinux it detects the UART component alright. I naively assumed that i...
16 years ago --- Quote Start --- By "this type of communication" I simply meant that support for the standard Linux system calls was implemented in the driver with the natural semantics. --- Quote End --- O have no idea what you mean by this. Embedded Linux _is_ standard Linux, as long you use features that are not configured to be missing to save resources. --- Quote Start --- By start a command shell you mean connect to the Nios via serial rather than JTAG UART? --- Quote End --- or additional to same by means of initab or by starting it from the shell. -Michael
