16 years agoRS232 with uCLinux
Hi, I am trying to set up communication between a PC and a DE2-70 board running uCLinux via the serial port. When booting uCLinux it detects the UART component alright. I naively assumed that i...
16 years agoBy "this type of communication" I simply meant that support for the standard Linux system calls was implemented in the driver with the natural semantics.
By start a command shell you mean connect to the Nios via serial rather than JTAG UART? Thanks for the help!
