14 years agoRS-422 to RS-232 Conversion
Hello Friends, I am trying to convert RS-422 data (arrive at 1 mbps) from remote machine in to a RS-232 format. remote machine/system send RS-422 data (CLK+, CLK-, DATA+ and DATA-) toward ...
14 years agoHello There,
I have follow the suggestion's w.r.t to your previous post. 1.Making data 32 bit. 2. trying non-interrupt version. 3.added a small fifo into the hardware (i do not know how do i do this --please suggest me ) i had tried the non-interrupt version of my Code (Below), but still didn't get proper data (sequence of 1,2,3....255)
# include <stdio.h>
# include <string.h>
# include <ctype.h>
/* RS232 Related Files....*/
# include "alt_types.h"
# include "altera_avalon_pio_regs.h"
# include "sys/alt_irq.h"
# include "system.h"
# include <unistd.h>
/* MicroC/OS-II definitions */
# include "includes.h"
/* Simple Socket Server definitions */
# include "simple_socket_server.h"
/* Nichestack definitions */
# include "ipport.h"
# include "tcpport.h"
# define HIGH 1
# define LOW 0
int CheckSync(int RxSync,int IndexRxSync);
int CheckReset(int RxResetSync,int IndexRxResetSync);
/* A variable to hold the value of the button pio edge capture register. */
volatile int edge_capture;
volatile int edge_capture2;
# define client_port 90
# define client_addr "192.168.1.207" //2nd Nios-2 Board RS-422 Conversion----Tx TCP Image
# define server_port 80
# define server_addr "192.168.1.66" //Linux Machine ....Image Server
# define PktSize 640//1920 //1920
# define PktCount 400//1000//1080
unsigned int mPktSize = 640;//397;
unsigned int mPktCount = 420;//288;
unsigned int Xstart = 0; //397; to be added in mPktSize (640) 640+640=1280 //MUST BE LESS THEN 1280
unsigned int Ystart = 0; //460; to be added in mPktCount(450) 450+420=870 //MUST BE LESS THEN 440
unsigned char ImgBuff;
int strt_sync = {164,92,51};
int end_sync = {235,144,3,30};
static void handle_load_interrupts(void* context, alt_u32 id)
volatile int* edge_capture_ptr = (volatile int*) context;
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 0);
static void handle_strt_interrupts(void* context2, alt_u32 id)
volatile int* edge_capture_ptr2 = (volatile int*) context2;
*edge_capture_ptr2 = IORD_ALTERA_AVALON_PIO_EDGE_CAP(STRT_OUT_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(STRT_OUT_BASE, 0);
//------------------Function to Send Data Bytes To Remote Machine (NIOS_II)----------------
//n32sendFd :: this is socket identifier
//chLocalBuffer :: this is the local buffer used by socket to send data
//n32RemainingBytes :: total no of bytes left after each iteration
//n32BytesSend :: bytes send
fnSendFunc(int n32sendFd, char* chLocalBuffer, unsigned int n32RemainingBytes, unsigned int n32BytesSend)
unsigned int n32Send=0;
while (n32RemainingBytes>0)
if ((n32Send = send(n32sendFd, chLocalBuffer+n32BytesSend, n32RemainingBytes, 0))<=0)
perror ("DMS fnSendFunc:send call");
close(n32sendFd);
return(perror);
n32BytesSend += n32Send;
n32RemainingBytes -= n32Send;
return (n32BytesSend);
void SSSSimpleSocketServerTask()
int sockfd;
int rc,s1;
int LPktCount = 0,Count =0;
struct sockaddr_in servaddr,cliaddr;
unsigned int DataCount = 0;
void* edge_capture_ptr = (void*) &edge_capture;
void* edge_capture_ptr2 = (void*) &edge_capture2;
int load = 0, strt_out = 0;
ssize_t addrlen;
addrlen = sizeof(servaddr);
// Enable 1 bit LOAD interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(LOAD_BASE, 0x1);
// Reset the edge capture register.
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(LOAD_BASE, 0x0);
alt_ic_isr_register(LOAD_IRQ_INTERRUPT_CONTROLLER_ID, LOAD_IRQ,handle_load_interrupts, edge_capture_ptr, 0x0);
// Enable 1 bit STRT_OUT interrupts.
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(STRT_OUT_BASE, 0x1);
//IOWR_ALTERA_AVALON_PIO_EDGE_CAP(STRT_OUT_BASE, 0x0);
alt_ic_isr_register(STRT_OUT_IRQ_INTERRUPT_CONTROLLER_ID, STRT_OUT_IRQ,handle_strt_interrupts, edge_capture_ptr2, 0x0);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xFF);
// RS232 Port Initialization
FILE* fp;
fp = fopen ("/dev/uart", "rb+"); //Open file for reading and writing
if(fp<0)
printf("RS232 Opening Error.!!\n");
else printf("RS232 Port Open....!!\n");
unsigned int n32RemainingBytes = 1920;
unsigned int n32BytesRecv = 0;
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xFE);
sockfd = socket(AF_INET, SOCK_STREAM, 0);
if(sockfd<0) printf("\nSocket creation error..!!\n\n");
else printf("\nSocket Created...!!\n");
servaddr.sin_family = AF_INET;
servaddr.sin_port = htons(server_port);
servaddr.sin_addr.s_addr = inet_addr(server_addr);
cliaddr.sin_family = AF_INET;
cliaddr.sin_port = htons(client_port);
cliaddr.sin_addr.s_addr = inet_addr(client_addr);
//setsockopt(sockfd,SOL_SOCKET,SO_RCVBUF,&n,sizeof(n));
//printf("Socket RECV_BUFF Set to 512X512..\n\n");
memset(&(servaddr.sin_zero),'\0',8);
// Bind with Client
if((bind(sockfd,(struct sockaddr *) &cliaddr,sizeof(cliaddr))<0))
perror("bind error .. !!");
exit(0);
else printf("Socket Bind...!!\n\n");
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xFC);
rc = listen(sockfd,5);
printf("\n\t#.Listening from remote Client...!!");
s1 = accept(sockfd,NULL,NULL);
printf("\n\t#. Accept The Connection...!!");
if(s1<0)
perror("accept call failed");
return;
else
printf("\n\t# Connection establish...!!");
printf("\n\t\t\tReady to Receive Serial data From remote Synchronous System\n");
edge_capture = 0;
edge_capture2 = 0;
while(1)
while(edge_capture2) //w.r.t. Start
edge_capture2 = 0; //reset generated STRT_OUT interrupt
LPktCount = 0;
Count = 0;
do
if(edge_capture) //w.r.t. clock or LOAD Pulse from "sync_detect"
edge_capture = 0; //reset generated LOAD interrupt
ImgBuff = IORD_ALTERA_AVALON_PIO_DATA(DATA_IN_BASE);
Count++;
if(Count == PktSize) //check end of packet-data -->640
Count = 0; //Point to Start of packet data
LPktCount++; //Increment packet Count
}while(LPktCount != (PktCount));
strt_out = IORD_ALTERA_AVALON_PIO_DATA(STRT_OUT_BASE);
if(strt_out ==1) //w.r.t. Start
LPktCount = 0;
Count = 0;
do
load = IORD_ALTERA_AVALON_PIO_DATA(LOAD_BASE);
if(load == 1) //w.r.t. clock or LOAD Pulse from "sync_detect"
//edge_capture = 0; //reset generated LOAD interrupt
Count++;
else
do
}while(load == 0);
printf("\n\t#Count = %d\t LPktCount = %d",Count,LPktCount);
printf("\n\t#Synchronous Data received...!!");
usleep(1000000);
printf("\n\t#Sending Data at RS232 Port at 115kbps...\n");
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0xF0);
printf("\n\t# Send Sync Word..");
for(Count = 0; Count<=2;Count++)
fprintf(fp,"%c",strt_sync);
//printf("\t%d",strt_sync);
printf("\n");
Xstart = 0;
Ystart = 0;
LPktCount = 0;
for(LPktCount = 0+Ystart; LPktCount<mPktCount;LPktCount++)
for(DataCount = 0; DataCount<mPktSize;DataCount++)
fprintf(fp,"%c",ImgBuff);
printf(">");
LPktCount = 0;
Count = 0;
printf("\n\t#Send Done....\n\t#Ready to receive Data.\n");
else
do
}while(strt_out == 0);
printf("\n\t\t\tConnection Closed ...");
close(sockfd);
fclose(fp);
printf("\n STRT_OUT = %d\n LOAD = %d",edge_capture,edge_capture2);
} //Close Simple_SOcket_Server
int SyncWord = {164,92,51};
int count;
int MatchCount = 0;
for(count = 0;count<3;count++)
if(RxSync == SyncWord)
MatchCount++;
IndexRxSync = (IndexRxSync + 1) % 3;
if(MatchCount == 3)
return 1;
else
return 0;
int ResetWord = {235,144,3,30};
int count;
int MatchCount = 0;
for(count = 0;count<4;count++)
if(RxResetSync == ResetWord)
MatchCount++;
IndexRxResetSync = (IndexRxResetSync + 1) % 4;
if(MatchCount == 4)
return 1;
else
return 0;
