BrendenB
2 years agoRiscFree debugging fails after first debug
I have a simple Nios V system that prints "Hello World" on a DE-10. The design is generated using Quartus Std Lite 23.1.1. The first time I try to debug, everything is fine. The second time I try to ...
- 1 year ago
Hi
Sorry in that cause you will need to wait for the release of Quartus Standard 24.1 in Q1 next year.
Jingyang, Teh
BrendenB
2 years agoI deleted the connection and tried again. Same result. Works the first time. Wont work again until I re-program the SOF.
I also tried deleting the connection after the error occurs and creating a new one. The connection can never be re-established until I re-program the SOF.
As I mentioned above, I am able to reproduce this outside of the IDE just using the command line tools manually (running them the same way the IDE does in the background). I'm not sure the IDE is playing a part here. Seems to be something wrong with the ash-riscv-gdb-server and/or the IP itself.
