Riscfree compilation error with message ".bss not within region onchip_mem"
Hi Rolando,
yes, you're right. When the path to Matlab is removed, I can compile with make instead of gmake.
I wonder if compiling with gmake is problematic since it is used in Linux systems? This is to avoid having to manage environment variables every time I need Risfree or Matlab.
One last question: are you getting the same warnings "File '/app/build/Debug/compile_commands.json' was not created in the build. Your workbench will not know all include paths and preprocessor defines." (my post 07-08-2025)?
Thank you for your help and thorough testing.
Thierry
Hi Thierry
Yes, I also see these warnings after I create the project with Riscfree:
Let me ask around about the issue of using gmake vs make. Not really sure if it's true that it tries by default using gmake instead of make.
Rolando
