20 years agorgd serial port as std i/o
Hi
i would like to clarify myself regarding the following. in two processor system if i attach serial port as std i/o tothe first processor(as per alphabetical order) and the other processor to jtag uart, if i run it is doing this by printing on the console as "can't open uart : permission denied" and then it stops what could be the reason? also i observe that it launches in the alphabetical order. please do comment on this. regards prasad3 Replies
Does it works if you remove the second CPU attached to JTAG uart?
it seems more a problem of the configuration of the peripherals on the first core... Paolo - Altera_Forum
Hi paolo
actually i have attached only one processor to the jtag uart and the other to the serial port. exclusively can u tell the reason. i am unable to get it. regards prasad - Altera_Forum
What I was saying is that the problem you have seems to me not relative to the fact you are using 2 CPUs.
Does the same problem happens when your design has just 1 CPU? Paolo
