12 years agoResource Collisions when installing PCIe DD
Does anyone know what this could mean ? Jan 1 00:30:22 linaro-developer kernel: [ 1822.434579] PCI: Device 0000:01:00.0 not available because of resource collisions I have the sample SG ...
12 years ago --- Quote Start --- Are there any tricks in converting from an environment controlled via Eclipse ( debug JTAG port ), to a system that is stand-alone, and starts without any Eclipse interaction? I would just like the JTAG UART to still communicate with the a NIOS terminal window or something similar. --- Quote End --- There is a NIOS II host-side console (command-line) program; nios2-terminal. Depending on your hardware setup, you may find it easier to move away from using JTAG for your UART (since it is inherently polled) to an FPGA-based UART connected to a UART-to-USB bridge (meaning that do you not have to have RS232 level translators). For example, FTDI has cables ... http://www.digikey.com/product-detail/en/c232hm-ddhsl-0/768-1106-nd/2714139 http://www.digikey.com/product-detail/en/c232hd-ddhsp-0/768-1011-nd/2767783 Cheers, Dave
