12 years agoResource Collisions when installing PCIe DD
Does anyone know what this could mean ? Jan 1 00:30:22 linaro-developer kernel: [ 1822.434579] PCI: Device 0000:01:00.0 not available because of resource collisions I have the sample SG ...
12 years agoHi Dave, I have the "producer / consumer" test running with my thin Linux device driver ...
You may have an idea on this ... and I assume it is a simple case of understanding how NIOS AVALON MM slave space is reached via BAR addresses in the Linux device driver. "The second issue I have relates to setting up the PCIe core Avalon MM -> PCIe address translation .. this is at a table with 2 entries of 4k bytes each. I am trying to track it down . This Cra register space is accessed via BAR1 and contains the physical address of the system DMA memory address. For some reason , that BAR1 write is ending up at a different location in IMEM that is just below the Cra space . I have an idea it could be something to do with the BAR address matching scheme and reference to NIOS address map. The IMEM is at 0x00010000 - 0x0001ffff and the CRA slave is at 0x00020000 - 0x00023fff ... the write to the translation tables at offest 0x00021000 in the CRA space seems to end up at 0x00011000 in the IMEM." Thanks, Bob
