14 years agoRESET THE NIOS PROCESS USING reset_n INPUT
Hello, i made a custom component in Qsys. This component has a reset input signal (conduit export) and a reset output signal (Reset Output interface). The reset output signal is connected t...
11 years agoHi , I am facing the same problem . I am new user to Nios , so can anyone please explain how to solve this issue ?
I have a Qsys system with Nios CPU , ON-chip ram and few PIOs . I initialize the on-chip RAM with a .hex file and create the .pof file. Once I burn the .pof inside the FPGA, on-chip RAM gets initialized and the Nios starts running as expected. But when the device is running , if I give a manual reset to the Qsys system with an external switch , the processor goes into a reset state and it stays in reset state even after i de-assert the reset switch. Also, when a power on reset sequence occurs, the processor will execute code correctly. It only mis-behaves when the reset occurs from an external switch input. Both the reset vector and exception vector of the Nios Processor is in the On-Chip RAM
