21 years agoreset & configuration revisited
I have some custom boards (cyclone, NiosIIe 33Mhz) that exhibits strange behavior on reset (either full POR OR soft reset (DEV_CLRn)). The behavior is that the Nios sometimes executes the code at the...
21 years agoIf you have an active probe for an oscilloscope kicking around (well something that expensive you don't just have it kicking around anyway), you may want to probe with it to limit the load you put into the circuit.
Good-luck (I know how much a pain these issues can be)
