21 years agoreset & configuration revisited
I have some custom boards (cyclone, NiosIIe 33Mhz) that exhibits strange behavior on reset (either full POR OR soft reset (DEV_CLRn)). The behavior is that the Nios sometimes executes the code at the...
21 years agoif you are using NIOS 1.1
also check http://www.altera.com/support/ip/processor...vkit1.1-er.html (http://www.altera.com/support/ip/processors/nios2/ips-nios2_devkit1.1-er.html) - Errors when booting from EPCS Device - JTAG UART is unstable after device-wide reset perhaps this helps
