19 years ago"Rescue" monitor idea
Our NIOS design has a field-upgrade capability via USB. As of right now we transfer the FW image (NIOS code or FPGA config), do a little checksumming and burn it into CFI flash (code) or EPCS (FPGA c...
19 years ago --- Quote Start --- originally posted by stonie@Mar 28 2007, 06:09 AM you could use 2 epcs devices for the two configs and a max cpld (with a built in watchdog) to switch between them...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22585)
--- quote end ---
--- Quote End --- I had this idea 2 year ago and implemented it, but two epcs devices are more expensive than 1 MAXII with a cfi .... now the design is coded into a maxii epm570f100 that does the fpga config, fail save fpga image handling (there is always a working image available), a watchdog, and of course 512bytes user flash available via spi (2MHz). The maxii device is full 100% used.
