13 years agoremoval of uClinux-dist and u-boot gits from sopc server
Dear all, As our network bandwidth is limited, we have to remove some git repo which are either deprecated or unnecessary. The uClinux-dist, which was cloned from Blackfin uclinux, was ...
12 years agoHippo,
Can you clarify a bit on what to use for the nios2 please? I've used both the non-mmu and MMU nios2 for years and want to make sure when I do a new project I have the lastest tools and kernel. I want to be able to do non-mmu AND MMU projects (sometimes you don't need all the mmu stuff). I tried the rocketboards niosII Linux and I don't see the pata_altera_cf driver that I used to use for my compact flash in branches that are now removed. I also used a known good *.dts and *.sof from the previous MMU version and I can get a kernel but it doesn't boot. I have a post on that but haven't gotten any responses. And this appears to be only MMU? Or is that now just a function of your *.dts file? So your statement: "We will use buildroot and yocto for nios2 rootfs/kernel/toolchain building in the near future" - can you elaborate. Also, I am getting into the Cyclone 5 and Soc environment tools soon but I'm assuming that's separate from nios2. I haven't fetched blackfin yet to look at it. Thanks in Advance
