19 years agoRemote Update using EPCS64 with Nios
Hi all. I am hoping somebody can help.
I have created a 'factory' image (fpga+nios code) that is stored at offset 0x0 in the EPCS64 device. So, it boots fine. Not to get too long winded, I have some code that can program new data in different places in the EPCS64 device. In my particular case, I am storing new fgpa+nios code at sector 32 (my old code ends in sector 15, so I am not overwriting any existing code). I can program and verify fine. I then use the remote update megafunction to reconfigure with the new firmware, and have problems. It seems to load the new fpga configuration code (all I did was turn on a LED in the new code), but it still runs my old nios code. It will not continue to load the new nios code and execute it. So, I believe my problem is with the bootloader portion? Any thoughts? I can program new code at offset 0x0, sector 0 over my old stuff (erase, and program new code at offset 0x0) and it works. However, I do not want to do this in field. I always want to keep my factory image for default in case the update does not work. I tried to do some research but having a hard time finding some answers. When I create my new files, I use the following commands // create fpga.flash from .sof# Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=C:/fpga_factory/fpga. sof --output=fpga.flash // create flash file from nios code# Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=fpga.flash --input=factory.e lf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2 /boot_loader_epcs_stratix_ii.srec Based on these commands, does the converter (for the bootloader or anything else) need to know any new addresses? Anyone have any recommendations? Do I need to be doing a different command or using a different bootloader? Thanks for your help!3 Replies
I'm about to try this myself. One thought - is your nios code in a M-RAM, that gets loaded by the EPCS boot loader, or are you using M4K's for your nios code with initialization in the FPGA config?
I plan to use the latter. If you're using the first, then your NIOS code isn't coming from FPGA config data, it's somewhere else in the EPCS flash, and I think the same code will be loaded regardless of which FPGA image is configured. \cb - Altera_Forum
And I succeeded in using the reconfig. Booting directly from the M4K onchip memory, I had no problem, so I suspect the original poster was storing code in the EPCS, and had both FPGA images point to the same address in EPCS to load the NIOS image.
I expect that if you use the EPCS boot loader, you would set a parameter that tells it where to locate the NIOS image, and you must set this parameter differently depending on your image. \chuck - Altera_Forum
--- Quote Start --- In my particular case, I am storing new fgpa+nios code at sector 32 (my old code ends in sector 15, so I am not overwriting any existing code). I can program and verify fine. --- Quote End --- Hi Simonsk, How can you achieve programming the second pair at sector 32 of EPCS64?
