19 years agoRemote Update using EPCS64 with Nios
Hi all. I am hoping somebody can help. I have created a 'factory' image (fpga+nios code) that is stored at offset 0x0 in the EPCS64 device. So, it boots fine. Not to get too long win...
19 years agoI'm about to try this myself. One thought - is your nios code in a M-RAM, that gets loaded by the EPCS boot loader, or are you using M4K's for your nios code with initialization in the FPGA config?
I plan to use the latter. If you're using the first, then your NIOS code isn't coming from FPGA config data, it's somewhere else in the EPCS flash, and I think the same code will be loaded regardless of which FPGA image is configured. \cb
