Paul83
2 years agoremote update module for cyclone 10 GX
I’m working with a Cyclone 10 GX FPGA with Quartus Prime 23.4.0 Build 79 11/22/2023 SC Pro Edition and the Ashling IDE v23.4.1, 3rd Nov 2023 using the remote update module to switch between factory...
NurAiman_M_Intel
2 years agoHi,
Afterward, we enable the watchdog by setting the RU_WATCHDOG_ENABLE parameter to 1. To prevent the system from reconfiguring to the factory image, we need to periodically reset the timer by writing a value to RU_RESET_TIMER.
However, it seems that the watchdog does not function as intended, even though it is enabled and the timer is not being reset.
-What do you mean it is not functioning as intended? What is the result of not functioning? Is the factory image automatically loaded or somethings else happened? What is the impact?
Aiman
