remote update module for cyclone 10 GX
-What is the result of time out parameter?
-What is the value that you set to the reset timer?
-Please provide scopeshot as per my previous response.
AIman
- Paul362 years ago
Hi Alman,
In the application program, I set the following registers:
IOWR_ALTERA_RU_CONFIG_MODE(REMOTE_UPDATE_BASE, 0x00); //Configures the factory image.
IOWR_ALTERA_RU_PAGE_SELECT(REMOTE_UPDATE_BASE, 0x20);//Starts at address 0x20 for the factory image.
IOWR_ALTERA_RU_RESET_TIMER(REMOTE_UPDATE_BASE, 0x00);//Does not reset the timer.
IOWR_ALTERA_RU_WATCHDOG_TIMEOUT(REMOTE_UPDATE_BASE, 0x0A);//Sets the timeout value to 0x0A.
IOWR_ALTERA_RU_WATCHDOG_ENABLE(REMOTE_UPDATE_BASE, 0x01);//Enables the watchdog.
After enabling the timer, the main loop continues to read back the watchdog timeout parameter, which same as the value I set with change in the timeout value:
IORD_ALTERA_RU_WATCHDOG_TIMEOUT(REMOTE_UPDATE_BASE, 0x0A); //Reads back the timeout value of 0x0A.
IORD_ALTERA_RU_WATCHDOG_ENABLE(REMOTE_UPDATE_BASE, 0x01); //Ensures the watchdog is enabled.
I expected that setting the timeout and enabling it without resetting the timer would trigger a reconfiguration after timeout value reduce to zero, but it did not (even the timeout value do not reduce). Please let me know if I misunderstood something.
To reset the timer, I set the value to 0 (IOWR_ALTERA_RU_RESET_TIMER(base, 0x0)) because I did not want to reset the timer and aimed to trigger the reconfiguration.
The reconfiguration process at higher DCLK frequencies has been resolved. The existing issue is with the watchdog timer not behaving as expected. I will return to the office next week and capture the waveform for your reference.
Paul
