PRibe4
7 years agoRemote system upgrade for MAX 10 with Cypress quad SPI Flash
I'm working on configuring a remote system upgrade (AN 741) with a dual image configuration using an external SPI flash to store the NIOS 2 hex (Boot option 5 from chapter 1.5.3.2 from AN 730). Curr...
Ahmed_H_Intel1
7 years agoHi,
Do you able to run the MEM-test project on this board, please make sure the mem-test passes with the flash device. Mainly I still suspecting the "Generic Quad SPI IP" parameters. please review the flash datasheet and run the mem-test before testing your design.
PRibe4
7 years agoHello, thank you for the reply.
I ran the memory-test project and it seems to stop after checking for erased blocks...
/dev/generic_quad_spi_controller2_0_avl_mem
-Successfully opened /dev/generic_quad_spi_controller2_0_avl_mem
-Region 0 contains 1024 blocks.
-Checking Region 0 for erased blocks.
Press enter to continue...I took a closer look at the datasheets from MT25QL512ABA and S25FS512S and there seems to be a diference in the sector sizes and dummy cycles mismatch.
How can I edit these parameters in the Generic quad SPI controler core II ?
