10 years agoRemote System Debug over Ethernet Cyclone V / Arria V
Hello
I am wondering if someone was able to port the Example how to get the Remote System Debug over Ethernet with the Arria 10 to on Arria V / Cyclone V ? Link to the Example: http://rocketboards.org/foswiki/view/projects/remotesystemdebug An Application Note about this: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an_693.pdf Regards Stefan3 Replies
Which part of the implementation are you having trouble with?
I patched the kernel used in this Instruction http://rocketboards.org/foswiki/view/documentation/yoctodorabuildwithmetaaltera
with the DebugHub drivers from here http://rocketboards.org/foswiki/view/projects/remotesystemdebug The result is https://github.com/nopeppermint/meta-altera which points to https://github.com/nopeppermint/linux-socfpga/tree/socfpga-3.10-ltsi => so I used git clone git://github.com/nopeppermint/meta-altera.git instead of git clone git://github.com/kraj/meta-altera.git in this Instruction http://rocketboards.org/foswiki/view/documentation/yoctodorabuildwithmetaaltera => I followed the Yocto build instructions and added this step: "bitbake -c menuconfig virtual/kernel" to select "Device Drivers/Character Devices/SLD HUB driver" so the driver was compiled. I manual added the mmlink application to the rootfs. => in Qsys a "SLD Hub Controller System" is added => the problem is somewhere between step 5-7 here http://rocketboards.org/foswiki/view/projects/remotesystemdebug as there is no connection :-( Do you have any suggestions/ideas ? - Altera_Forum
--- Quote Start --- the problem is somewhere between step 5-7 --- Quote End --- Means the server is started, system console can be selected in signal tap but you don't get "JTAG ready"? I would check if the sever is connecting and responding by wireshark. If connecting but not responding check the embedded code. If responding but no valid JTAG communication, check the SLD_Hub connection.
