10 years agoRemote System Debug over Ethernet Cyclone V / Arria V
Hello I am wondering if someone was able to port the Example how to get the Remote System Debug over Ethernet with the Arria 10 to on Arria V / Cyclone V ? Link to the Example: http:/...
10 years agoI patched the kernel used in this Instruction http://rocketboards.org/foswiki/view/documentation/yoctodorabuildwithmetaaltera
with the DebugHub drivers from here http://rocketboards.org/foswiki/view/projects/remotesystemdebug The result is https://github.com/nopeppermint/meta-altera which points to https://github.com/nopeppermint/linux-socfpga/tree/socfpga-3.10-ltsi => so I used git clone git://github.com/nopeppermint/meta-altera.git instead of git clone git://github.com/kraj/meta-altera.git in this Instruction http://rocketboards.org/foswiki/view/documentation/yoctodorabuildwithmetaaltera => I followed the Yocto build instructions and added this step: "bitbake -c menuconfig virtual/kernel" to select "Device Drivers/Character Devices/SLD HUB driver" so the driver was compiled. I manual added the mmlink application to the rootfs. => in Qsys a "SLD Hub Controller System" is added => the problem is somewhere between step 5-7 here http://rocketboards.org/foswiki/view/projects/remotesystemdebug as there is no connection :-( Do you have any suggestions/ideas ?
