16 years agoregion on chip memory is full error .. plz help
hello
im compiling the "hello world" example using a hardware design with 32k Byte memory on chip and Im getting these errors that can't be solved.. !! any ideas? Description Resource Path Location Type make: *** [serial1.elf] Error 1 serial1 0 C/C++ Problem region onchip_memory2_0 is full (serial1.elf section .text). Region needs to be 16292 bytes larger. serial1 0 C/C++ Problem section .bss [0000a004 -> 0000a217] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem section .rodata [00008020 -> 00008513] overlaps section .exceptions [00008020 -> 000081c3] serial1 0 C/C++ Problem section .rwdata [00008514 -> 0000a003] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem waiting your replies thanks3 Replies
Try compiling the Hello World Small example.
Hi
Error is because you overlapped the boot address and exception address Try Changing the exception address to some other memory regards M Kalyansrinivas - Altera_Forum
The regular Hello World example will not fit in 32k. You'll have to use the unhosted version (Hello World Small).
Jake
